I have the student version of AutoCAD 2012 on an HP laptop with Windows 7 Home Premium OS. I originally installed AutoCAD in June of 2012. It worked fine for 9 or 10 months but now whenever I select File/Open, File/Save, or File/Save As, AutoCAD stops responding and the spinning blue donut appears. AutoCAD never comes back and I have to close it from Task Manager. I uninstalled AutoCAD and reinstalled it, and the process went smoothly. However I still have exactly the same problem with the File operations. I apply Windows updates, but other than that have not made any changes to the software on the laptop. AutoCAD works fine for everything except the File operations. I am able to save with CTL/S and am able to open AutoCAD files from File Manager.
Did you install anything after the time AutoCAD's save-dialog did work normal?
If not do you have the chance to do a Windows system restore to a point/date before the problem started?
- alfred -
I don't have so many ideas now (except of try to uninstall that software), you might try:
a) disconnect your workstation from any network (and try AutoCAD then)
b) disable antivirus-sw (and other defending software)
c) login with another user-account (having admin-permissions)
d) start AutoCAD with right-click option "start as administrator"
...if any of these trials give you the filedialogs back you will have a chance.
HTH, - alfred -
