AutoCAD 2010/2011/2012
New Member
cbjdennis
Message 1 of 21 (24,015 Views)
AutoCAD 2012 Trial Download
24015 Views, 20 Replies
01-10-2013 03:06 AM
Is it possible to still download a trail of AutoCAD 2012?
AutoCAD 2013 is unsitable due to compatibility issues with add-ons, so ideally I need to download a trial of AutoCAD 2012 to check compatibility before I purchase a licence.
Thanks in advance,
Callum.
camilo.lemos
Message 2 of 21 (24,009 Views)
Re: AutoCAD 2012 Trial Download
01-10-2013 03:36 AM in reply to: cbjdennis
Hi Callum and welcome to the forums!
I can provide you with download links for AutoCAD 2012 but I have to mention that AutoCAD 2012 licenses are no longer being sold by Autodesk nor by our resellers. In order to be able to use an AutoCAD 2012 license, you would need to purchase the 2013 version with subscription and then take advantage of the previous version usage benefits provided by Autodesk subscriptions.
Here are the links - please note that they will expire in 72 hours:
AutoCAD 2012 32-bits
AutoCAD 2012 64-bits
Let me know if you need any further info!
Camilo Lemos
New Member
cbjdennis
Message 3 of 21 (24,003 Views)
01-10-2013 04:01 AM in reply to: camilo.lemos
Thanks for the links and license information Camilo.
Inciner
Message 4 of 21 (23,804 Views)
02-15-2013 08:42 AM in reply to: camilo.lemos
Once again, please.
I'm otoy's octane-to-autocad plugin's tester, current version of plugin requires for 2012 x64.
Can you update the link?
philip.s
Message 5 of 21 (23,798 Views)
02-15-2013 10:18 AM in reply to: Inciner
Hello Inciner,
I've just sent the requested links via Private Message (small envelope next to your name at the top of the page when signed in).
For future reference, you can request supported previous version media / download links directly via our Media Request Form.
Philip Schmelzer
New Member
spaantech311
Message 6 of 21 (23,296 Views)
04-05-2013 08:59 AM in reply to: philip.s
Will you help me please?  I also need the 32-bit trial of AutoCAD 2012 for Windows XP.  Thanks
philip.s
Message 7 of 21 (23,271 Views)
04-05-2013 04:11 PM in reply to: spaantech311
Welcome to the community Manish!
You can now download most current + supported previous version releases of Autodesk software directly from Matt, our Virtual Assistant. Check out this AutodeskHelp blog post for more info on how to access Matt and navigate to the afore mentioned download links.
Philip Schmelzer
New Member
gosisters
Message 8 of 21 (19,992 Views)
07-15-2013 02:23 AM in reply to: philip.s
Hi Philip,
Can you guide me through Matt to download the AutoCAD 2012 Trial? I am unable to get the download links from Matt.
A separate question, if we had purchased the 2014 version, will we be able to downgrade to the 2012 version via a media request in the customer assistance form? I am currently on Vista OS and it is not compatible with 2014 version. Thank you!
Charles_Shade
Message 9 of 21 (19,976 Views)
07-15-2013 06:28 AM in reply to: gosisters
Welcome to the Autodesk Forums!
Typically if you are on Subscription what you are asking is allowed as you have access to several versions previous. Though if it is one license this "downgrade" is meant for one user only even on subscription.
If this is a new Seat of AutoCAD then what you purchased is that seat only and not a previous version.
If this is an Upgrade to the 2012 then you are allowed a short time period to run both so that you can get the new version up to speed but you will be in violation of the EULA if you continue to run the original 2012 Seat and the Upgrade at the same time; say with two different users.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Valued Contributor
tbennett
Message 10 of 21 (19,967 Views)
07-15-2013 07:43 AM in reply to: Charles_Shade
Hey Charles. I like your tag line. I'm going to plagiarize... if you don't mind.
Please mark "Accept as Solution" if your question is answered. Kudos gladly accepted.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
