AutoCAD 2010/2011/2012
Distinguished Contributor
Message 1 of 14 (11,480 Views)
AutoCAD 2011 file new, open, save and save as problem.
11480 Views, 13 Replies
01-25-2011 05:10 AM
For the last couple of days whenever I need to use the file new, open, save, save as, menu commands I do not get the window'ed option to access the commands but rather a text like option - like the pre-windows Autocad -  which prompts me for the options.  See the picture.
For the life of me I cannot figure out what I have changed or done wrong to have this happen now.  I would really like to change it back, and will appreciate any help available.
Murph
Message 2 of 14 (11,478 Views)
Re: AutoCAD 2011 file new, open, save and save as problem.
01-25-2011 05:13 AM in reply to: KobusE
type in FILEDIA and set it to 1.
Murph
Supportting the troops daily.
Message 3 of 14 (11,471 Views)
01-25-2011 05:24 AM in reply to: Murph
Thank you sir :-)
Active Contributor
Message 4 of 14 (11,166 Views)
02-11-2011 09:06 AM in reply to: KobusE
I am having a similar problem. My file open dialog seems to be popping under my AutoCAD window and will not let me access it. The only thing I can do is cancel the command and use the MRU menu or search via explorer and open that way. Any ideas?
Message 5 of 14 (11,157 Views)
02-11-2011 10:21 AM in reply to: Timothy_Dike
Have you tried the above suggestion?
Active Contributor
Message 6 of 14 (11,155 Views)
02-11-2011 10:47 AM in reply to: ToanDN
Yes, I have and it makes no difference. When the dialog box pops under or wherever it goes, I am locked out of any input on the main screen. Have dealt with the cmddia and filedia variable getting reset in the past, but this is not that problem. I can change it to command prompt entry and manually type in the file name and path, but when I change it back I can not access the dialog box. Everything was working fine unil today.
I have a new monitor and have tried adjusting the resolution, just in case the box is opening elsewhere outside the monitor screen area. But no joy.
Active Contributor
Message 7 of 14 (11,036 Views)
02-15-2011 11:15 AM in reply to: Timothy_Dike
I was able to solve my problem by switching the primary monitor in my control panel. AutoCAD was forced to screen 2 and the dialog box opened where I could access it. I moved it and switched monitors back and now it doesn't open off screen.
New Member
cjenkins
Message 8 of 14 (10,954 Views)
02-17-2011 11:43 AM in reply to: Murph
Thank you! We've had this problem at my office, and FILEDIA fixed it.
New Member
Message 9 of 14 (8,225 Views)
03-02-2012 09:34 AM in reply to: cjenkins
Murph Thaaaaaaaaaaaaanks!!!
JGerth
Message 10 of 14 (8,216 Views)
03-02-2012 12:32 PM in reply to: Timothy_Dike
After the Open command is run, and the file dialog is invisible (but there's not a command line prompt asking for a fle name) hit the <ALT><SpaceBar> combination, and the M.  After that, you can use the arrow keys to drive the dialog box back into visibility.
If there's a commandline prompt, you can use the tilde ~ c=haractor to force the file dialog to appear, and then remember to reset FILEDIA to 1 after you've opened the drawing.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
