AutoCAD 2010/2011/2012
Member
Message 1 of 8 (1,990 Views)
AutoCAD 2011 Ribbon Menu
1990 Views, 7 Replies
03-29-2010 01:09 AM
I install AutoCAD 2011.It is working normally on AutoCAD Classic. But change it 3D Basic get error.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eNotApplicable
at Autodesk.AutoCAD.Runtime.Variable.set_Value(Object value)
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.SetRibbonState(Boolean value)
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.RibbonPaletteSet_StateChanged(Object sender, PaletteSetStateEventArgs e)
at Autodesk.AutoCAD.Windows.PaletteSetStateEventHandler.Invoke(Object sender, PaletteSetStateEventArgs e)
at Autodesk.AutoCAD.Windows.PaletteSet.FireStateChange(StateEventIndex value)
at Autodesk.AutoCAD.Windows.AcMgPaletteSet.OnWindowPosChanging(AcMgPaletteSet* , tagWINDOWPOS* lpwndpos)
at Autodesk.AutoCAD.Ribbon.Win32.CallWindowProc(IntPtr lpPrevWndFunc, IntPtr hWnd, Int32 Msg, IntPtr wParam, IntPtr lParam)
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.WndProc(IntPtr hWnd, Int32 Msg, IntPtr wParam, IntPtr lParam)
at CWnd.ShowWindow(CWnd* , Int32 )
at Autodesk.AutoCAD.Windows.Window.set_Visible(Boolean value)
at Autodesk.AutoCAD.Windows.PaletteSet.set_Visible(Boolean value)
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.set_Visible(Boolean value)
at Autodesk.AutoCAD.Ribbon.Commands.Ribbon()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 18.1.0.0
Win32 Version: 18.1.49.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcdbMgd.DLL
msvcm90
Assembly Version: 9.0.30729.4148
Win32 Version: 9.00.30729.4148
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e/msvcm90.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.1427 built by: SP
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.0.264.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdApplicationFrame.DLL
AdWindows
Assembly Version: 3.0.263.0
Win32 Version: 3.0.263.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdWindows.DLL
PresentationFramework.Luna
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Luna/3.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/acmgd.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.1 built by: SP
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcCui.DLL
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
ManagedMC3
Assembly Version: 4.11.0.0
Win32 Version: 4.12.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/ManagedMC3.DLL
PresentationFramework.Aero
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcLayer.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
*Tony Tanzillo
Message 2 of 8 (1,990 Views)
Re: AutoCAD 2011 Ribbon Menu
03-29-2010 04:37 AM in reply to: birber
What's "3D Basic" ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6362415@discussion.autodesk.com...
3D Basic get error. See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box. **************
Exception Text ************** Autodesk.AutoCAD.Runtime.Exception: eNotApplicable
at Autodesk.AutoCAD.Runtime.Variable.set_Value(Object value) at
Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.SetRibbonState(Boolean value) at
sender, PaletteSetStateEventArgs e) at
Autodesk.AutoCAD.Windows.PaletteSet.FireStateChange(StateEventIndex value) at
tagWINDOWPOS* lpwndpos) at Autodesk.AutoCAD.Ribbon.Win32.CallWindowProc(IntPtr
lpPrevWndFunc, IntPtr hWnd, Int32 Msg, IntPtr wParam, IntPtr lParam) at
wParam, IntPtr lParam) at CWnd.ShowWindow(CWnd* , Int32 ) at
Autodesk.AutoCAD.Windows.Window.set_Visible(Boolean value) at
Autodesk.AutoCAD.Windows.PaletteSet.set_Visible(Boolean value) at
Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.set_Visible(Boolean value) at
Autodesk.AutoCAD.Ribbon.Commands.Ribbon() at
commandObject, Boolean bLispFunction) at
mi, Object commandObject, Boolean bLispFunction) at
bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies ************** mscorlib Assembly Version:
2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase:
file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ----------------------------------------
acdbmgd Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase:
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcdbMgd.DLL ----------------------------------------
msvcm90 Assembly Version: 9.0.30729.4148 Win32 Version: 9.00.30729.4148
CodeBase:
file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4148_x-ww_d495ac4e/msvcm90.dll -
--------------------------------------- System Assembly Version: 2.0.0.0 Win32
---------------------------------------- System.Xml Assembly Version: 2.0.0.0
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll -
--------------------------------------- System.Drawing Assembly Version: 2.0.0.0
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll -
--------------------------------------- PresentationFramework Assembly Version:
3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll -
--------------------------------------- WindowsBase Assembly Version: 3.0.0.0
file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll -
--------------------------------------- PresentationCore Assembly Version:
file:///C:/WINDOWS/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll -
--------------------------------------- AdApplicationFrame Assembly Version:
0.0.0.0 Win32 Version: 3.0.264.0 CodeBase:
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdApplicationFrame.DLL ----------------------------------------
AdWindows Assembly Version: 3.0.263.0 Win32 Version: 3.0.263.0 CodeBase:
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdWindows.DLL ----------------------------------------
PresentationFramework.Luna Assembly Version: 3.0.0.0 Win32 Version:
file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Luna/3.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll -
--------------------------------------- acmgd Assembly Version: 18.1.0.0 Win32
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/acmgd.DLL ----------------------------------------
System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll -
--------------------------------------- AcWindows Assembly Version: 18.1.0.0
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.DLL ----------------------------------------
System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.1 built by: SP
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll -
--------------------------------------- AcWindows.resources Assembly Version:
---------------------------------------- AcCui Assembly Version: 18.1.0.0 Win32
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcCui.DLL ----------------------------------------
ContextualTabSelectorRules Assembly Version: 0.0.0.0 Win32 Version: 18.1.49.0.0
CodeBase:
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.dll ----------------------------------------
System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll -
--------------------------------------- ManagedMC3 Assembly Version: 4.11.0.0
Win32 Version: 4.12.0.0 CodeBase:
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/ManagedMC3.DLL ----------------------------------------
PresentationFramework.Aero Assembly Version: 3.0.0.0 Win32 Version:
file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll -
--------------------------------------- AcLayer Assembly Version: 18.1.0.0 Win32
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcLayer.DLL ----------------------------------------
AcLayer.resources Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0
CodeBase:
file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcLayer.resources.DLL ----------------------------------------
************** JIT Debugging ************** To enable just-in-time (JIT)
debugging, the .config file for this application or computer (machine.config)
must have the jitDebugging value set in the system.windows.forms section. The
application must also be compiled with debugging enabled. For example: When JIT
debugging is enabled, any unhandled exception will be sent to the JIT debugger
registered on the computer rather than be handled by this dialog box.
Member
Message 3 of 8 (1,990 Views)
03-29-2010 05:16 AM in reply to: birber
Workspace is "3D Basics", "3D Modeling", "2D Drafting & Annotation" so included ribbon menu in WorkSpace.
*Dean Saadallah
Message 4 of 8 (1,990 Views)
03-29-2010 05:33 AM in reply to: birber
Explore the 2010 area for JIT error messages: security settings in
Windows/IE and .NET reinstalls seem to be the popular fix.
Dean Saadallah
http://LTisACAD.blogspot.com
*Tony Tanzillo
Message 5 of 8 (1,990 Views)
03-29-2010 11:20 AM in reply to: birber
Don't allow Dean to waste your time.
The exception you're getting has nothing to do with .NET
configuration or system security settings, it is a bug.
wrote in message news:6362491@discussion.autodesk.com...
Member
Message 6 of 8 (1,990 Views)
03-29-2010 11:32 PM in reply to: birber
I try reinstall. Between use clean .net tool and download .net sp1 full.But I get it error.
Now format pc and setup vista x86.I install clean setup for autocad 2011.I get it error but working AutoCAD and ribbon menu.If change workspace, AutoCAD crash. Edited by: birber on Mar 30, 2010 6:33 AM
Valued Mentor
hardin
Message 7 of 8 (1,990 Views)
03-31-2010 02:37 PM in reply to: birber
I've had issues with AutoCAD crashing while changing Workspaces when I had partial menus loaded.
I don't really remember exacly what it was, but something about changing a profile, which moved my partial menu to the enterprise menu (or vic versa) then if I tried to change workspaces, it crashed.... Sorry I can't get more specific, but generally look at what your workspaces are trying to pull up based on menus and partial menus. Good luck.
Learn, Practice, Get Better
http://autocad-lkh.blogspot.com
Member
Message 8 of 8 (1,990 Views)
04-06-2010 07:40 AM in reply to: birber
Thank you.
This problem resolved. AutoCAD 2011 not work on other language support xp or vista. Only working on English supported Xp.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
