AutoCAD 2010/2011/2012
Misfittoy
Message 1 of 7 (2,856 Views)
Auto update page numbers
2856 Views, 6 Replies
06-08-2012 06:44 AM
I am setting up a template and want my page #s to automatically update when i copy a tab. How is this done? I currently have my "Total Sheets" as a field and that works out fine but often need to add/ remove a sheet to/from drawing and would like the page #s to update.
Thank you
Valued Contributor
wolfgrrl
Message 2 of 7 (2,840 Views)
Re: Auto update page numbers
06-11-2012 05:04 AM in reply to: Misfittoy
Try looking at this:
http://heidihewett.blogs.com/my_weblog/2006/03/sheets_happen_s_4.html
I am unable to view this at work, but it may be what you need.
This looks promising as well....
http://www.cadtutor.net/forum/showthread.php?11537-Good-Question-Layout-names-and-fields&p=64089#pos...
Autocad Mechincal 2012 on Windows 7 64-bit
rkmcswain
Message 3 of 7 (2,826 Views)
06-11-2012 10:28 AM in reply to: Misfittoy
We wrote our own routine to do this.
It renumbers the sheets (from 1 to n) in SSM and updates the "TotalSheets" custom field.
Nothing built into AutoCAD to do this.
Misfittoy
Message 4 of 7 (2,814 Views)
06-12-2012 06:15 AM in reply to: Misfittoy
Thank you for the responses.
Do you have/did you write a field code for this?
We do not use sheet sets in our drawings,so i am looking for a way to automatically update  page numbers. As seen in the image, the "TOTAL SHEETS" is a field which i update from properties manager. I would like to find a solution to the "SHEET NO." that if i copy/add or delete a tab this number updates. Possible?
rkmcswain
Message 5 of 7 (2,812 Views)
06-12-2012 06:40 AM in reply to: Misfittoy
Misfittoy wrote:
We do not use sheet sets in our drawings.....
Sounds like you'll need a reactor that periodically polls the number of layout tabs and updates the field accordingly.
Sorry, I don't know of any existing tool that does this
Short of using a reactor, you could use a lisp function like below, and then point your Field to the lisp variable. Of course you have to execute the lisp statement to update the variable, which in turn will update the field. You could piggy back this code inside a shortcut to a command you use often (such as LINE, ERASE, QSAVE)
; this lisp statement will return the
; number of layouts in the current drawing
; and set the result to a lisp variable named mytotalsheets
(setq mytotalsheets (length (layoutlist)))
; example of the piggy back idea
(defun C:E ()
 (command "._erase")
Product Support
Shawn_Niles
Message 6 of 7 (2,801 Views)
06-12-2012 12:46 PM in reply to: rkmcswain
Great suggestions here everyone. Please click on 'Accept as Solution' for any posts that will help to solve this for you.
Shawn Niles
Valued Mentor
tim.turner
Message 7 of 7 (2,790 Views)
06-13-2012 05:43 AM in reply to: Misfittoy
It is not totally automatic but if you want to standardize your tab names you can pull certain parts of the tab name into a field with diesel. Our tabs begin with SH 1, SH 2, SH 2A etc. The field in the title block has this diesel string: $(substr,$(getvar,ctab), 4,2) which pulls the 4th and 5th characters. You can adjust the numbers to pull whatever part of the tab name you want.
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
