Is there a way to change the text styles, lets say from "Standard" to "Romans", all at once within an attributed block, or do you have to update each tag attribute individually?
Solved by Alfred.NESWADBA. Go to Solution.
you can edit the blockdefinition, change there the attributedefinitions to have the other textstyle. After finishing the blockeditor with saving start command _ATTSYNC and all block-insertions of that type will get updated.
- alfred -
