AutoCAD 2010/2011/2012
Active Member
aeisenberg
Message 1 of 5 (378 Views)
Assigned colors are lost when importing STEP or Solidworks file
378 Views, 4 Replies
11-15-2011 07:45 AM
does anyone know if you can import step files into ACAD2012 and keep the colors from my native SolidWorks model?  It imports into ACAD with all of the components in monochrome.  After that import, it also won't change the colors when I try to do it manually in properties/color by layer, etc.
*Expert Elite*
Message 2 of 5 (373 Views)
Re: Assigned colors are lost when importing STEP or Solidworks file
11-15-2011 09:47 AM in reply to: aeisenberg
Was is saved in SWx using STEP  AP 214 ?  My colors transfer from SWx to AutoCAD through STEp as long as I don't use textures or transparent colors.  Must set Options to AP214 though.
Attach sample file here.
http://forums.autodesk.com/t5/Autodesk-Inventor/Assigned-colors-are-lost-when-importing-STEP-or-Soli...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
Message 3 of 5 (367 Views)
11-15-2011 09:53 AM in reply to: aeisenberg
aeisenberg wrote:
... After that import, it also won't change the colors when I try to do it manually in properties/color by layer, etc.
After import is it Blocks or is the geometry Solids?  Run List.
Explode once.
Attach your original *.stp file here.
Active Member
aeisenberg
Message 4 of 5 (364 Views)
11-15-2011 09:57 AM in reply to: JDMather
Here's the step file (AP214) - created in SW2011.  The only options checked off are solid/surface geometry and split periodic faces.
*Expert Elite*
Message 5 of 5 (355 Views)
11-15-2011 01:11 PM in reply to: aeisenberg
The header indicates it was created in SWx 2010 - but as you have found - for some reason the color information is not coming into AutoCAD.  It does read back into Inventor and into SolidWorks.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
