AutoCAD 2010/2011/2012
GTVic
Message 1 of 5 (883 Views)
Arial Text in Block Looks Bold when Rotated 90
883 Views, 4 Replies
04-30-2012 05:38 PM
We have some blocks that have static text labels on the left and numeric attributes on the right. When these blocks are rotated so the text is near vertical the static text has a bold appearance.
If you explode/burst the block then this 'bold' appearance goes away. If you rotate the text to normal then the effect disappears as well. The bold appearance shows up on a plot as well. The effect is subtle at times but noticeable.
Sample drawing attached, see the block near the top of the drawing and a copy of it rotated to normal. Use the BURST command on the block on the left to see the change.
pendean
Message 2 of 5 (868 Views)
Re: Arial Text in Block Looks Bold when Rotated 90
05-01-2012 04:53 AM in reply to: GTVic
TTF fonts do that if Z height is anything other than zero: SHX fonts don't have this issue.
Explore using FLATTEN express tool.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
3wood
Message 3 of 5 (861 Views)
05-01-2012 06:52 AM in reply to: GTVic
If current UCS is not WCS and the Z axis of UCS is not vertical, the extrusion of objects changes after rotation.
This is also one of the reasons Mtexts change appearence after printing.
Please try CHZ20.vlx to reslove it.
3wood
CAD KITS
GTVic
Message 4 of 5 (851 Views)
05-01-2012 11:40 AM in reply to: pendean
The FLATTEN command resolves the issue but it does it by creating a new copy of the block with a new name with all of the internal entities changed to yellow instead of BYBLOCK and all entities in the block are now rotated and scaled to match the rotation and scale of the previous block insertion. The new block is inserted with rotation 0 on layer 0.
The side effects of the FLATTEN command are not acceptable. The CHZ20 command had no effect.
It appears as though text in a block that is rotated because of the block insertion is affected. Attributes are not affected even though they are using Arial. There is no issue with UCS or Z or extrusion as the UCS is WORLD and PLAN is CURRENT UCS and I can take the flattened version and adjust the affected properties and the problem comes back.
The only solution in my case appears to be to make all of the labels on the left side of the block into attributes. I can't even make them constant attributes, that doesn't work. So preset attributes is the solution for now. My guess is that this is because attributes are adjustable, AutoCAD renders them differently, probably slows down the drawing.
GTVic
Message 5 of 5 (818 Views)
05-07-2012 11:09 AM in reply to: GTVic
The response from Autodesk to my subscription support request is that this is a known issue.
The more people that report problems related to this issue, the more likely it is that it will be addressed.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
