AutoCAD 2010/2011/2012
Active Contributor
dlbellotte
Message 1 of 6 (218 Views)
Annotative Objects - Aarrg!
218 Views, 5 Replies
06-08-2012 05:04 PM
Like using annotative objects in 2012.  Have annoautoscale set to -4.
Everything good until today.  All of a sudden all objects have all scales.  Drawing is a mess!
For some reason it acts like all scales apply to all annotative objects.  So I have to spend hours deleteing and re-adding scales.  What happened? anybody else experienced this?
Bob_Zurunkle
Message 2 of 6 (201 Views)
Re: Annotative Objects - Aarrg!
06-10-2012 05:08 AM in reply to: dlbellotte
Do you work in an office with a practical joker for a coworker? It sounds like somebody messed with your settings...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Active Contributor
dlbellotte
Message 3 of 6 (196 Views)
06-10-2012 08:18 AM in reply to: dlbellotte
No merry prankster involved.  It just happened.
Thought I had annoautoscale disabled with the default setting (-4).
Now I see r2013 has a setting of 0.
Is that a valid setting in 2012?
Product Support
Dan.Scales
Message 4 of 6 (166 Views)
06-18-2012 07:01 AM in reply to: dlbellotte
The setting of 0 is also in 2012:
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ffa23ce210c875431153da8....
Could you also confirm if setting the variable back to 4 solved this for you?
Dan
Dan Scales
Active Contributor
dlbellotte
Message 5 of 6 (145 Views)
06-19-2012 05:06 AM in reply to: dlbellotte
I will try setting at 0.
Active Contributor
dlbellotte
Message 6 of 6 (133 Views)
06-19-2012 09:15 AM in reply to: dlbellotte
the drawing has been behaving since after I went through it and deleted scales.
autoannoscale (I believe) was set to -4.
It is now set to zero.
I usually keep an eye on the "lightning bolt/tri-scale" icon in the tray and it seeems it has always been turned-off.
Lets wait and see if it happens again (I hope it does, so I will know I am not crazy), then I will stop immediately on the drawing and send it.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
