So whenever I export my Civil3D drawing to Acad the Annotation Scale in the paper space is still set to 1:1000 and i can't load my templates because they are way to small. I don't know why but in older drawings where i used exacte the same Civil3D drawing template and exported them to Acad the Annotation scale in the paperspace have always been set to 1:1
Check the Annotation Scale of a viewport in the drawing the Export to AutoCad is being done from.
If this is always happening starting from the same template as you mention, then verify the VP scale is
set to desired scale in the dwt file.
If Iset the Viewport Annotation Scale to 1'=1000 here and Export to AutoCad using Civil 3D 2014, the resulting
ACAD-export.dwg has a viewport annotation scale of 1'=1000 (or whatever I had this value set to) prior to export.
In the future please post Civil 3D related topics in the AutoCad Civil 3D General Forum .
