AutoCAD 2010/2011/2012
Member
39CentStamp
Message 1 of 4 (2,187 Views)
Add Text To a Line - How To ?
2187 Views, 3 Replies
12-23-2010 09:19 AM
With Visio i can easily add text to a line like the example below. How can i do this with AutoCAD?
At another forum the suggestion was to "Convert the line to block and make the text an attribute. The attribute will move with the block". I have been trying to figure out how to do this since last night with no luck.
Is there an easier way to accomplish the task? If not can someone walk me thru (or point me to ) the steps to make the line a block and make the text an attribute?
New Member
Message 2 of 4 (2,170 Views)
Re: Add Text To a Line - How To ?
12-23-2010 11:01 AM in reply to: 39CentStamp
Go to the Insert menu and choose Field...
Choose the Comments field.  Attach the field to your line.  Select the field and replace the default characters with your text.
Invoke the Properties command and change the justification of the field to Middle Center.  Turn the Background Mask on and use the drawing background color as your fill.  Use the Insert osnap and move the field to the location of your choice on the line.
*Expert Elite*
Message 3 of 4 (2,152 Views)
12-23-2010 02:40 PM in reply to: drhaefne
Why create a field then make it become regular text?
*Expert Elite*
Message 4 of 4 (2,149 Views)
12-23-2010 02:55 PM in reply to: 39CentStamp
Use constrain command: GcCoincident
See attached sample.  Attribute block is another approach but from looking at your example you probably don't need it.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
