AutoCAD Forum
ACAD 2012 Communication Center / Need ADSK Help
2 REPLIES 2
SRayC
282 Views, 2 Replies
We have been fighting ACAD 2012 freezing during launch. Very sporadically. Finally figured out it was the wscommcntr3.exe (InfoCenter) not closing when ACAD was shut down. I found that there is a similar issue with 2011 products. I also found information on how to turn InfoCenter off through registry setting changes, but this is not very desirable. Is there a HotFix to correct this issue.
Ray C.
2 REPLIES 2
dmfrazier
in reply to: SRayC
Here is a link to the available Service Packs and "Fixes" for 2012:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618#section3
Since AutoCAD is currently at 2014 versions, it's not likely there will be any additional "Fixes" for 2011 or 2012.
jggerth1
in reply to: dmfrazier
question for the OP:  What is undesirable about killing the Infocenter completely?  What value do you find in it, or what beneficial purpose does it serve in your operation?
”Boost
