AutoCAD Forum
2D drawing full with 3D points
7 REPLIES 7
Message 1 of 8
nicolasoterob
513 Views, 7 Replies
Hi guys,
I have an entire 2D project full with 3D points.
Lines, polylines, blocks etc... with z coordinates.
Properties manager dosent solve the problem and flatten kind of distroys my xrefs.
Sometimes even 2 Z=0 elements are consider not to be coplanar.
Is there any way to solve these? I´m seroiusly thinking of starting from zero....
NOB
7 REPLIES 7
Message 2 of 8
hwalker
in reply to: nicolasoterob
Try this
^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0​,-1e99;
Howard Walker
Left Handed and Proud
Message 3 of 8
Kent1Cooper
@nicolasoterob wrote:
I have an entire 2D project full with ... Lines, polylines, blocks etc... with z coordinates.
... flatten kind of distroys my xrefs.
Since Flatten involves object selection, would it work to have something build a selection set of everything except Xrefs, and using Flatten on that selection?  Try it manually, with a limited selection of things you know are off, and not including any Xrefs, and see whether it corrects those appropriately.
Kent Cooper, AIA
Message 4 of 8
nicolasoterob
in reply to: hwalker
Thanks man,
I tired it, and Its virtually a big bang.
Great portion of the drawing stayed in place, but about 10% of it went as far as jupiter. ZOOM extents prohibited...LOL
So its' dificult to verify objects current positions through views.
I'll left the file attached if anyone wants to check it out.
Message 5 of 8
nicolasoterob
in reply to: Kent1Cooper
Look's like throw indivudual selection, flatten works. Although some blocks tend to colapse.
Message 6 of 8
3wood
You need be careful when using FLATTEN because it creates different block definitions after changing same block instances.
Message 7 of 8
Kent1Cooper
I think it should be possible to make something that would select everything, and for Xrefs and Blocks, simply force their insertion points to a Z value of 0, and for everything else, apply Flatten.  Is that worth pursuing?
Kent Cooper, AIA
Message 8 of 8
In these archive blocks dont response to properties positon. Its a vert slow process
”Boost
