I have a polyline in the attached file that does not show any z vertex in the properties box, but when you ID ther verticies, each vertex has a different Z value
The polyline has an elevation, but the z value at the verticies don't match that.
Can someone shed some light on this?
Cheers,
Brent
When you inquire the entity information with LIST command, you will see all different Z value of vertexes.
It is a LWPOLYLINE, not a 2D Polylines, definitely every vertex can has its own Z value.
It's not drawn in [or parallel to] the World Coordinate System. You can tell by the last entry in the entity data list, which is the extrusion direction, meaning the direction [in unit-vector form] of the Z axis of the object in relation to the WCS:
(210 0.000325872 0.000500258 1.0)
For something drawn in the WCS, or in a User Coordinate System parallel to it, that would be:
(210 0.0 0.0 1.0)
so it's pretty close to lying parallel to the WCS. You can also tell that it's close by the fact that the Z coordinates span a small range in relation to its length.
The elevation of it:
(38 . 168.526)
is in relation to the origin under which it was drawn and its extrusion direction. For a LWPOLYLINE drawn in or parallel to the WCS, if you List it when you are in the WCS, that number will be the same as all the Z coordinates in the List results. Or if you set the UCS to match it {UCS command, OBject option], List will show all Z coordinates as 0.
Try to convert this pline to 3D POLYLINE
