• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    pipeman449
    zoom extents in paperspace
    603 Views, 4 Replies
    08-22-2011 12:06 PM
    when i use zoom extents command in ps layout flies way off into space and i cant get it back unless i undo. please help with limits or scale
    Please use plain text.
    *Expert Elite*
    pendean
    Re: zoom extents in paperspace
    08-22-2011 12:09 PM in reply to: pipeman449
    There is probably something, a block or a line or another entity, far-far away from your page: Zoom Extents means just that, find everything and zoom out to include them all.
    Try ERASE command and go around the edges with a window.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Contributor
    Julesagainn
    08-25-2011 01:33 PM in reply to: pendean
    I have had this problem pop up on occasion - make sure everything is unfrozen and unlocked, so you can find whatever object is hanging out there.
    Distinguished Contributor
    MKH-VB
    08-29-2011 07:45 AM in reply to: Julesagainn
    also check for a wipeout w/ frame turned off.  That has burned me in the past.
    mkh
    *Expert Elite*
    Bob_Zurunkle
    08-29-2011 09:12 AM in reply to: MKH-VB
    OP is your VP locked?
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
