• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Distinguished Mentor
    Moshe-A
    weird crosshair
    236 Views, 7 Replies
    06-13-2012 02:21 AM
    Hi Guy,
    this is very weird case
    have a specific drawing that the crosshair in the Y direction is broken (sse attached image)
    excectly in middle of screen this problem was seen also in older autocad realses (R2008)
    the UCS is world and PLAN view is set
    the screen is OK the display card + driver is OK
    the weird thing is this is only in this dwg and even if it insert it to fresh dwg in comes good
    any body seen this?
    thanks in advance
    Moshe
    Please use plain text.
    Re: weird crosshair
    06-13-2012 02:32 AM in reply to: Moshe-A
    never seen, but I also don't work with that large cursor
    If that is true, upload this drawing, otherwise we can't reproduce it (as it does not appear in any other drawing).
    You already have loaded the drawing with _RECOVER or checked it with command _AUDIT?
    - alfred -
    Alfred NESWADBA
    *Pro
    nestly
    Re: weird crosshair
    06-13-2012 02:58 AM in reply to: alfred.neswadba
    I see it in the X direction as well (left)
    SNAPANG 0.00000000, perhaps?
    Moshe-A
    Re: weird crosshair
    06-13-2012 09:30 AM in reply to: nestly
    Alfred,
    yes the file is AUDIT
    Nestly,
    i admit at the time i was looking at the file it didn't occur to me about snapang
    the file is from a consultant office i support, tomorrow i will take a look again
    and if it's not snapang i will post it here
    thanks again for your help
    moshe
    Patchy
    Re: weird crosshair
    06-13-2012 09:36 AM in reply to: Moshe-A
    If the file converted from Microstation .dgn, some of them do that.
    Moshe-A
    Re: weird crosshair
    06-13-2012 01:14 PM in reply to: Patchy
    Patchy,
    wow, you know that for sure? but what is that inside that causes it?
    but i do not think that this is the case here, as i said earlier i will check it tomorrow
    and let all know
    thanks for this input
    Patchy
    Re: weird crosshair
    06-13-2012 01:18 PM in reply to: Moshe-A
    Sure I'm sure, .dgn convert to .dwg and the cursor got rotated in Autocad.
    You can Google to see if others see it as I have.
    Here is one:
     http://forums.autodesk.com/t5/AutoCAD-2004-2005-Archive/cursor-rotation/td-p/1831013
    Moshe-A
    Re: weird crosshair
    06-13-2012 11:41 PM in reply to: Moshe-A
    Guys
    That was it SNAPANG
    and it could be came from some conversion from other platform
    but the consultant office does not sure about it
    Thank you very much all
    Moshe
