• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    visibility parameter in a block
    136 Views, 2 Replies
    06-01-2012 05:37 AM
    I am trying to have my block with differnet visibility options but i dont want a long list to choose from under one parameter.  If I did what I am wanting to in one visibility it would be a very lond list of differnet comination options. The list would have 16 differnet options. Is there a way to have multiple visibilty parameters?
    Please use plain text.
    bgingerich
    Re: visibility parameter in a block
    06-01-2012 08:01 AM in reply to: jamied2000
    Depending on what you're doing, look into a block properties table.  Or if you search a little in this forum or the dynamic block forum there is a multiple visibility lisp floating around.  HTH
    Brandon Gingerich
    Member
    06-01-2012 08:44 AM in reply to: jamied2000
    It can be done with lookup tables to control the visibility states.  DBs support multiple grips for lookup tables.
    Here is a thread that covers it pretty well.
    http://forums.autodesk.com/t5/Dynamic-Blocks/Multiple-Lookup-Grips-how/m-p/1520248
    Also attached are a few examples that I created that have two grips that toggle between 32 visibility states but there are 4 choices in one grip and 8 in another.
