• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    u command disabled
    262 Views, 7 Replies
    10-03-2012 11:30 AM
    "u command disabled use undo command to turn on" has anyone ever gotten this message? it seems to only happen to 1 draftsman and i can figure out why
    Please use plain text.
    jonmcfarlandWS
    Re: u command disabled
    10-03-2012 11:39 AM in reply to: andrew.nao
    There may be a script or routine that is disabling the command.  Is that system different than any other?
    Jon
    Please select "Accept as Solution" if your question was answered.
    curtainwallBIM.blogspot.com
    Valued Mentor
    leothebuilder
    You can disable a command by entering  _UNDEFINE in the command line followed by the command you want to undefine.
    You can redefine a command by entering _REDEFINE in the command line, followed by the command you want to redefine.
    pendean
    10-04-2012 05:55 AM in reply to: andrew.nao
    Look up UNDOCTL variable in HELP, it explains how to "turn it on".
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    10-05-2012 10:31 AM in reply to: pendean
    undo isnt turned off or disabled, just the use of "u" for undo gets disabled all work stations are the same
    Valued Mentor
    leothebuilder
    10-05-2012 10:37 AM in reply to: andrew.nao
    Dis you change the .pgp file and assinged "U" to some other command ?
    10-08-2012 07:59 AM in reply to: leothebuilder
    the pgp file is ok
    pendean
    10-08-2012 09:30 AM in reply to: andrew.nao
    Then you have an add-on or third party tool or startup choice someone at your end made for you that removed U from your access: it works fine here OOTB for all of us.
    What you got?
