• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    *Expert Elite*
    Re: these are the errors i am getting
    12-28-2012 02:16 AM in reply to: jh2274
    as you get a second link for download from anyone at Autodesk ask that person if he can try the unpackaging? I think it's needed for you to verify if it's the sourcefile or your download.
    When the source-file at Autodesk is OK you have to get the file downloaded from another workstation/using another internet-provider.
    If you send me the link (and no login-data) I also can try if I get it downloaded with or without CRC-error.
    Good luck, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Please use plain text.
    *Expert Elite*
    12-28-2012 03:59 AM in reply to: jh2274
    ok, I got your links via PM and downloaded them (I think that are the default links for downloading it as trial-version).
    I copied the downloaded files into a folder C:\TEMP on a fresh Win7x64SP1 virtual machine and started the EXE with right-click and option "start as administrator".
    All went fine, all installed, AutoCAD was startable without any issue.
    I recorded the full session as video, if you like to see it (the file has some MB), I upload it anywhere.
    So the result is: you need a clean Win7 installation,
    One thought, just to make sure: if you download the files multiple times you get different filenames like filex(1).exe and file(2).exe .... so if you did a new download without deleting the files downloaded previously the unpackager may unpack the wrong file (and so you can download and download and download, it's always the same "first file" that may be used for installation).
    Sorry not to have a final solution, - alfred -
    Alfred NESWADBA
    12-28-2012 12:18 PM in reply to: alfred.neswadba
    ok download and extraction went fine, now getting this on installation;
    2012/12/28:12:16:22 James JAMES-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\James\AppData\Local\Temp\vcredist_x86_2010.log
    2012/12/28:12:16:25 James JAMES-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
    *Expert Elite*
    12-28-2012 12:51 PM in reply to: jh2274
    do you really have enough rights to install?
    When I read this message:
    ... I would try to do the installation of VCREDIST/start this exe directly and see what happens:
    ... or I would look into the log file that is reported to be saved here:
    - alfred -
    Alfred NESWADBA
    12-28-2012 01:06 PM in reply to: alfred.neswadba
    I get this trying to install direct as an administrator
    12-28-2012 01:12 PM in reply to: jh2274
    and this
    2012/12/28:13:10:19 James JAMES-PC Installing Autodesk® Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Design_Suite_Standard_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/12/28:13:10:59 James JAMES-PC Install Autodesk® Material Library 2012 Failed Installation aborted, Result=1603
    *Expert Elite*
    12-28-2012 01:14 PM in reply to: jh2274
    then remove the newer installation of VCREDIST (within Windows control panel ==> software) and start the installation of AutoCAD again.
    - alfred -
    Alfred NESWADBA
    01-15-2013 06:07 PM in reply to: alfred.neswadba
    the video would be great, thank you for your time. -- James Harrison Snr Project Manager Associated Design Group PO Box 26037 Kamloops, BC V2C 0A9 Tel: 250.319.6905 Email: jharrison.adg@gmail.com
    *Expert Elite*
    01-15-2013 10:14 PM in reply to: jh2274
    animierte smilies denkende denken schlau grübeln
    - alfred -
    Alfred NESWADBA
