AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
(softlock license manager) is not functionin g or is improperly installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just installed autocad and this is what happened on the first boot. I've uninstalled, rebooted, reinstalled and rebooted and still got this error. What can I do?
Here is the exact error: The security system (softlock license manager) is not functioning or is improperly installed
Re: (softlock license manager) is not functionin g or is improperly installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is most certainly a file permissions problem. Make sure you give Everyone full rights to the following folders/files:
On Vista or Windows 7:
C:\ProgramData\FLEXnet\adskflex_*.data
C:\ProgramData\FLEXnet\adskflex_*.data.backup
On Windows XP:
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*.data.backup
Always install and run your Autodesk products with local Administrator privileges.
For faster responses concerning Autodesk licensing issues, please post your questions in the Installation and Network Licensing user forum here:
http://forums.autodesk.com/t5/Installation-Licensi
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: (softlock license manager) is not functionin g or is improperly installed
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This solution did not work. Is there anything else I can try? Do I need to uninstall and reinstall? I am running Windows Vista 32 bit.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
its a late reply, but since i got the same problem (and this is the first hit you get on google) i will tell you how to fix it
shut down the software
simply DELETE the files mentioned above!
Empty recycle bin!
Reopen the software, type in license key again
problem fixed ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
what about windows 8??? i just can't find these files!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is a Ps to my last post, All my other programs in the suite work.
Now my "cad" just does not even try to open. just shuts down and I dont the Softlock error after deleting the files, and no place to put a serial number.
