• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    snapang 30 150
    254 Views, 4 Replies
    07-28-2012 06:21 AM
    In 2001 I posted a question about setting the crosshairs one at a 30 degree angle and the other at a 150 degree angle.  Someone had told me how to do it and I set it in a toolbar button.  Since then, my hard drive had to be replaced and I neglected to write the procedure down.  I believe it was done with the "snapang" command but I can't get the 2 crosshairs to each set at a different angles.  Can anyone help me?  Thanks.
    Please use plain text.
    Distinguished Mentor
    Moshe-A
    Re: snapang 30 150
    07-28-2012 09:52 AM in reply to: mplatton
    yes, you are close:-
    Snap Aspect Isometric
    New Member
    Re: snapang 30 150
    07-28-2012 11:29 AM in reply to: Moshe-A
    Thank you for your response, but it is not quite what I'm looking for.  Snap Aspect only asks for horizontal and vertical spacing on the grid settings; Snap Style Isometric places the crosshairs at 60 and 90 degrees.  I'm trying to set the cross hairs at 30 and 150 degrees.  Thanks anyway.
    Moshe-A
    Re: snapang 30 150
    07-29-2012 12:58 PM in reply to: mplatton
    Oh sorry i meant
    Snap Style Isometric (and it's 30 & 90 & 150)
    Distinguished Contributor
    Re: snapang 30 150
    08-07-2012 08:23 AM in reply to: mplatton
    Using the isometric settings for snap, then rotating snap -30º will give you the 30º & 150º snap settings yuo are looking for. you may have to tap the f5 key till it cycles to isoplane top.
