• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Member
    kmankov
    slow responce time
    215 Views, 4 Replies
    11-04-2011 12:57 PM
    responce time for entering comand is slow. For example if I press m (for move) then hit enter right away AutoCAD would not react, so every time i have to hit enter 2 or 3 times right after every command (really annoying). Probably I'm too quick for the programm, but I hope there is a way to make it faster (like that control for double clicking in windows). Or may be there is any other way. Please bring any suggestions. Thank you.
    Please use plain text.
    Re: slow responce time
    11-04-2011 03:50 PM in reply to: kmankov
    try to play with dynamic input (<F12>) and also one possible reason could be if you have not docked the commandline-window into the application window ... and worst case for that would be undocked plus on the second monitor.
    - alfred -
    Alfred NESWADBA
    Active Member
    kmankov
    11-07-2011 03:06 PM in reply to: kmankov
    Thank you. That solves my question. Hopefully Autodesk will fix that.:smileyhappy:
    11-08-2011 01:34 AM in reply to: kmankov
    Have you sent them the problem and the solution? If not they can't, you didn't tell us which of my above tips solved it for you :smileywink:
    - alfred -
    Alfred NESWADBA
    Active Member
    kmankov
    12-12-2011 09:16 AM in reply to: kmankov
    I just closed command line. Immidiately it become super fast. So the problem was with command line.
    PS. Good drafter does not need command line anyway. ctrl+9 and ctrl+0 rule and modified acad.pgp rule :smileyhappy:
