• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    AFitchguy07
    Re: slow autocad after block editor
    02-06-2011 11:53 AM in reply to: *elenist
    I, too, just started having this issue yesterday. I have been using 2011 full since last summer and never had any issues until yesterday. It was driving me nuts! Zoom e does work for me to prevent the jumpy cursor.
    I did notice acad.exe in task mngr does go up to about 40% of cpu ussage when i exit block editor and move the cursor around only within the application. Not sure what it is. Would love to figure out what it is since it worked fine until yesterday.
    Windows 7 Ultimate x64
    Acad 2011
    Please use plain text.
    Member
    02-08-2011 06:28 AM in reply to: AFitchguy07
    Hello!!! We need help. Where are the autodesk people. This is a huge problem since autocad 2010 was working fine and because of the obligation of licence renwal i'm stuck with a program that is faulty....
    New Member
    AFitchguy07
    02-08-2011 07:22 AM in reply to: Loomsdak
    Does zoom extents not work for you? I had 2011 and it worked fine until last week.
    Valued Mentor
    LeafRiders
    02-16-2011 03:10 PM in reply to: AFitchguy07
    I seen this happen today on another guy's machine. I had to reopen AutoCAD and it was fixed, but make sure you have nothing else open with your session of AutoCAD. Often times this can be a virtual memory thing. Autodesk will most likely pin it on this anyway so may as well close all other acad sessions and even mail etc. and then try to replicate it. If it happens then you have issues.
    Ensure you have all the service packs, drivers, and hot fixes, seems to be a long list. Also, i've also found that turning my regenauto setting off helps out. I redefined my "RE" command to be regenall.
    New Member
    RobMorris6253
    05-23-2011 05:18 AM in reply to: LeafRiders
    Is there a resolution to this issue its a real pain inserting blocks, editing them, and then zoom extents, regen, zoom back in.
    Just installed 1.1 update and no change!!!!!!!
    Autocad LT 2011
    New Member
    dfarrellnep
    12-14-2011 11:43 AM in reply to: RobMorris6253
    Still no solution to this? Ridiculous. Very unproductive on large drawings where I have to zoom all and regen---then find where I was working...
    *Pro
    12-14-2011 11:45 AM in reply to: dfarrellnep
    When I upgraded my machine from WinXp 32bit to Win7 64bit, I have yet to see that problem.
    azr
    New Member
    10-01-2012 11:48 PM in reply to: *elenist
    Try setting your Display Properties.
    Right Click on Desktop select Properties / Settings / Advanced /  Trouleshoot - try dicrease your Hardware acceleratoin or Start / Control Panel / Display / / Settings / Advanced /  Trouleshoot. Hope its work
