• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    amritsaundh577
    .sld file snapshot file
    1264 Views, 2 Replies
    09-25-2010 07:23 AM
    what is .sld file? How it is inserted or used with autocad.
    Please use plain text.
    Valued Mentor
    Re: .sld file snapshot file
    09-25-2010 09:43 AM in reply to: amritsaundh577
    Those are slide files - pictures of dwgs. Draw a circle inside a rectangle and then type Mslide. You will then get a picture of the rectangle with circle. Redraw closes a slide. Look up in Help.
    Murph
    09-25-2010 04:29 PM in reply to: amritsaundh577
    In old versions that used the menus (pre ribbon days) the sld files were used to display images of parts, blocks, line tyes, hatch types and etc. You could also use them in the slide player to create an animation of a drawing. I used to make a group of them years ago to use as a screensaver in the dos days.
    Murph
    Supportting the troops daily.
