• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Member
    ribbon issues
    200 Views, 10 Replies
    12-07-2012 05:23 AM
    MY ribbon has stopped changing with selections. It used to show hatch options when the hatch command was active, it no longer does this... It would also show hatch options if I selected a hatch with grips, and show other options for other entities if selected with grips, it no longer does this. What worng with it?
    Please use plain text.
    Re: ribbon issues
    12-07-2012 05:30 AM in reply to: malform
    verify two settings:
    PICKFIRST
    RIBBONCONTEXTSELECT
    - alfred -
    Alfred NESWADBA
    Member
    Re: ribbon issues
    12-07-2012 05:47 AM in reply to: alfred.neswadba
    Thank you for your quick reply.
    Unfortunately those settings didnt not fix the issue.
    PICKFIRST was already on (1), and RIBBONCONTEXTSELECT was initially set to 1, I tried RIBBONCONTEXTSELECT on 0, 1, and 2 and it made no differance.
    pendean
    Re: ribbon issues
    12-07-2012 06:08 AM in reply to: malform
    What did you recently change or add (or delete) in AutoCAD 2012?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    Re: ribbon issues
    12-07-2012 06:13 AM in reply to: pendean
    The only thing I have altered recently is that I created my own workspae, and removed some pulldowns that I never use.  I dont know if this is the cause or not. But I do know if I switch to other workspaces, it still doesnt work like it should.
    Re: ribbon issues
    12-07-2012 08:05 AM in reply to: malform
    And you are sure you have not modified any context-menu's also? After reading you have modified the CUIX that would be the first location to search.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    Re: ribbon issues
    12-07-2012 08:30 AM in reply to: malform
    Can one of you guys help me with my post
    Member
    Re: ribbon issues
    12-07-2012 09:31 AM in reply to: alfred.neswadba
    I can honestly say that I do not know if I inadvertanly modified any context menus. My only goal, and the only thing I did intentionally, was remove pulldowns.... How can I restore the menu to a pre-modified state?
    pendean
    Re: ribbon issues
    12-08-2012 08:37 PM in reply to: malform
    Member
    Re: ribbon issues
    12-10-2012 05:35 AM in reply to: pendean
    Pendean, you are amazing!
    Thank you so much, reset option worked.
    Oddly, the pulldowns I removed are still gone, so I dont have to go back and tweak anything.
