• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    jcalexander
    publishing dialoge won't accept changes for layer settings.
    67 Views, 2 Replies
    06-12-2012 08:20 PM
    My issue is with the Publish dialogue.  I am publishing several sheets to PDF.  I do not want layers to be available in the PDF.  I shoud be able to control whether or not layers export with the PDF in the "Publish dialogue box > Publish Options > General DWF/PDF options > Layer Information"  (then there are two options, either to include or not include layer information).  However, when I change it to "don't include" and close out of that box, the main Publish dialogue still shows the layer option as included and the layers are in the PDF after I publish it.  Any ideas on why the layers still show up?
    Thanks much.
    Please use plain text.
    bgingerich
    Re: publishing dialoge won't accept changes for layer settings.
    06-13-2012 05:34 AM in reply to: jcalexander
    In order to prevent layers from being shown in a pdf, turn them off or freeze them.  The "include layer information" option includes the layers with the pdf (over on the left with the bookmarks and such).  You can alternately turn on and off layers directly in the pdf with the "information included."  But to not include layers in a pdf, they must be off, frozen, or locked when creating the pdf.  HTH
    Brandon Gingerich
    Active Contributor
    itbemedg
    06-13-2012 06:01 AM in reply to: bgingerich
    I can publish just fine to PDF and my layers are not shown and I don't freeze, lock or turn off anything.
    Don't know why the OP's won't do the same. Anyone?
