• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    uncisbest
    popup height/depth/angle/etc. box is missing
    217 Views, 3 Replies
    03-20-2012 12:47 PM
    When i used to draw a rectangle, circle, line, etc- a box (or several) boxes popped up after i clicked the first point. These let me enter the distance then hit the tab button and go to a second box to enter height or angle depending on what i was drawing.  There was also some popups that showed up when clicking the chamfer or fillet buttons but now those are all gone.  When i input numbers, it goes to the command bar.
    I didnt change anything and am frustrated.  How can i get those small popup windows to reappear in my modelspace?
    Thanks, in advance.
    Please use plain text.
    Active Member
    uncisbest
    Re: popup height/depth/angle/etc. box is missing
    03-22-2012 06:36 AM in reply to: uncisbest
    bump.
    JGerth
    03-22-2012 10:08 AM in reply to: uncisbest
    look up dynamic input in help
    Active Member
    uncisbest
    03-22-2012 10:21 AM in reply to: JGerth
    thanks for your help.  Somehow my DYNMODE value was set to -3 instead of 3.  when i switched it back, everything worked as it used to.
