AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
place text along an arc (not like Express arc text)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I want to place text along an arc as shown in example dwg, how do this using array or other method?
Re: place text along an arc (not like Express arc text)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I placed the text manually along the arc to illustrate what I want to accomplish.
I was asking how would I place text along the arc as shown on the attached drawing (automatically)
I want the text to be place perendicular to the arc as show on the drawing.
FX
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Make the text and the underline to become a block and use this block to measure along the arc.
If they're not suppose to be equally spaced, make the text and the underline a block with its insertion point at the center of the arc and then use insert command.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the text must be different for each instance, make it an attributed block. And follow patchy's advice by using "measure" command for equal distance spacing.
or,
If you want to get fancy you can create an attributed dynamic block, with the center of arc as base. Then stretch and /or rotate for custom spacing which you could use on varying radii of different arcs.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And if the text is to go on radial tick marks (as in your example) add an alignment parameter to the dynamic block.
Dave.
Dave Hein, P.E.
