• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    paperspace dimensioning
    156 Views, 3 Replies
    04-30-2012 08:06 AM
    I keep having problems with dimensions scaling properly in paper space. What is the correct procedure for setting up and maintaining a viewport and layout so the scale stays correct for model space dimensions? I'm new at this method of dimensioning.
    Please use plain text.
    *Expert Elite*
    GrantsPirate
    Re: paperspace dimensioning
    04-30-2012 08:49 AM in reply to: tulsaoffice
    Set DIMASSOC to 2.  Osnap to points in MS through the viewport.  You can't snap from one vp to another one.  Your dimstyle will be set so that on the Fit tab you will either pick Annotative, or Scale dims to layout, or Use overall scale of 1.
    I think that is about it.
    New Member
    04-30-2012 10:42 AM in reply to: tulsaoffice
    Thanks, must be the dimstyle, they have a setup program that sets the scale for dims and annotations here for Model Space. Probably whats causing the conflict.
    *Expert Elite*
    3wood
    05-01-2012 06:34 AM in reply to: tulsaoffice
    Please try STARTUPCHECK.vlx which provides maintenance of the scale matching between paperspace and model space.
    3wood
    CAD KITS
