• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Accepted Solution
    nested blocks
    261 Views, 6 Replies
    04-13-2012 01:31 PM
    Is there a quick/easy way to know if a DWG constains nested blocks?
    Please use plain text.
    *Expert Elite*
    Re: nested blocks
    04-14-2012 01:20 AM in reply to: Kevin078
    Not without development.
    Whatfor do you need that? For the structure of a drawing it's irrelevant if there are nested blocks or not, isn't it?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    Re: nested blocks
    04-14-2012 01:41 PM in reply to: alfred.neswadba
    We're managing a project that includes handing over ACAD DWGs we didn't create, so they can be converted to  MicroStation DGNs. We've been informed the DWGs being converted can't have nested blocks. We've also been told the DWGs don't contain nested blocks, but we'd like to confirm that before handing them to the the client.
    *Expert Elite*
    Re: nested blocks
    04-14-2012 02:21 PM in reply to: Kevin078
    so it will end in development (or you upload DWG(s) and anyone of us will check them for you, hopefully).
    Thinking about the internals of how a DWG-file is structured each DWG: as the modelspace is one blockdefinition and if you have inserted one (or more) BlockReferences info it it's already a nested block situation .... but I don't think you mean that, do you :smileywink:
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    Re: nested blocks
    04-15-2012 11:41 AM in reply to: alfred.neswadba
    Please define 'development' in this context.
    *Expert Elite*
    Re: nested blocks
    04-15-2012 11:52 AM in reply to: Kevin078
    There is no built in function within AutoCAD that lists the nested Blocks in a drawing. That has to be developed: a small programm has to be written that scans through the blocks and creates that list.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    Re: nested blocks
    04-15-2012 11:53 AM in reply to: alfred.neswadba
    Ok, thanks for the info.
