AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
navigating too many layout tabs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello - I have inherited some drawings that have around 42 layout tabs (yikes!). I have never worked with a drawing that has as many tabs as this.
I'm looking for an easy way to bounce between tabs without having to hit the arrow buttons to scroll through them all.
I'd like to redo the files to not have as many tabs, but I do not have the option to do this right now.
Thanks for any ideas anyone has.
Don
Re: navigating too many layout tabs
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Would the Quick View Layouts button, at the bottom of the UI, be better?
Jon
Please select "Accept as Solution" if your question was answered.
curtainwallBIM.blogspot.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can also switch and sort layouts using a dialog but try it yourself - if it is more convenient. See the layout manager - LOMAN:
http://www.cadforum.cz/cadforum_en/ana-alternative
Vladimir Michl, http://www.cadstudio.cz
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Jon - that does help but it still requires scrolling through the tabs. The UI is faster at scrolling than it is going through the arrow buttons. But thanks for the reminder on using the UI.
Don
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Vladimir - this is exactly what I was hoping I could find!
Thanks for the link - this is perfect!
Don
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What I do is name a View for each Layout Tab. For example, my Layouts are A.1, A.2, A.3, ...to A.50. While in the first Layout, A.1, I name the View "A.1", and so on for each Layout Tab. While in Paperspace, I can recall any of the Named Views and it will go to that View immediately. Try it, you'll like it. -KLYPH
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Great idea KLYPHY - and once it is set up, it provides a nice listing of all the layout tabs inside of the VIEW dialog box.
In the case I have now, I have been given these drawings done by someone else and they did not set up views for each tab. So the LOMAN routine worked great and I also used the LAYOUT command followed by a "?" to give me a listing of all the tabs which I copy pasted in to a Word Doc.
But this is a great tip to remember because it does not require any external lisp routine, it utilizes AutoCAD's own commands.
Thanks for the tip.
Don
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Before I name a View for a Layout, I set the display to be the whole sheet, not less, not more. That way, even if I leave a Layout zoomed way in to some detail, when I restore the View back to that Layout, it goes to the full sheet. Save a lot of time. Read Ya Later -KLYPH
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Cansel - Autodesk Division
http://www.cansel.ca/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Of course the Sheet Set Manager is the way to go. But it does take moving the cursor, scrolling down, selecting, and often a time delay before the Sheet comes up. In the case that started this discussion, there were move Layouts than normal. Even in the Sheet Set Manager, there would have been a lot of scrolling.
I may not have shared that our Office has a lisp for views. If the Layout is A.1, we merely type "V1" and it goes to Layout A.1. We type V20 and it goes to Layout A.20. We developed that lisp back in the early 90s, before there were even any Layouts, just the one Paper Space.
So, I do what I call "The Closest". If my hand is on the mouse, I would go to the Sheet Set Manager. If my hands are on the keyboard, I type "V1", etc.
The Sheet Set Manager was one of the greatest AutoCAD inventions.
Read Y'all Later -KLYPH
