• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    cvriend
    move/stretch displacement setting
    1014 Views, 3 Replies
    12-07-2010 09:35 AM
    I want to move some linework using the move command, selecting a base point on the linework and then entering an X,Y coordinate for the final point. Some setting in AutoCAD, however, is automatically inserting an "@" before my entered coordinates when I hit return, giving me different results than what I desire.
    I know this setting can be turned off, since I've used this method many times before, but I can't locate the setting or variable.
    Help, please!
    Please use plain text.
    Valued Mentor
    Re: move/stretch displacement setting
    12-07-2010 10:33 AM in reply to: cvriend
    the @ sign is probably coming in from having Dynamic Input turned on - check your status bar at the bottom (crosshairs with a box next to it, or "DYN" if you've turned off using icons).
    Distinguished Mentor
    jaich
    12-07-2010 12:53 PM in reply to: cvriend
    Preface your coordinate input with #.  That way you can leave DYN on.  DYN assumes relative coordinates (the @ symbol), the Pound symbol forces absolute coordinates for that part of your command.
    Employee
    08-11-2011 10:07 AM in reply to: cvriend
    If you go to Dsettings on the Dynamic Input Tab there is Pointer Input - Settings and there you can change from Relative (@) to absolute (#).
    Dan
    Autodesk Inc
