• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    mbuttonpan
    139 Views, 3 Replies
    02-04-2013 07:53 AM
    dear sir,
    when i open one drawing i want to change mbuttonpan value is 1. how can change the value 1 ever? and polyline thickness also i want to change in option. please send the solution.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: mbuttonpan
    02-04-2013 08:10 AM in reply to: muhammedriyas
    MBUTTONPAN variable stores in the registry, no reason to change in a drawing.
    PLINEWID stores in a drawing, change it in your template drawing.
    For any drawing that you open and you need to set default PLINEWID, make it happen by using ACADDOC.LSP
    New Member
    Re: mbuttonpan & ployline
    02-04-2013 08:54 AM in reply to: muhammedriyas
    Dear sir,
    As my previous mail, I don't get clear answer from you. Please mention how I can solve these problems?
    1) I need to change mbuttonpan value 1, when I open every drawing.
    2) I need to change polyline width in option, when I open every drawing.
    Please give the correct answer for these problems, or attached jpg for this.
    *Expert Elite*
    Patchy
    02-05-2013 06:30 AM in reply to: muhammedriyas
    MBUTTONPAN is a variable you set it once and it doesn't change the next time you open another drawing, if you have to reset it to 1 all day, you need to repair your autocad.
    PLINEWID is not a variable you change in OPTIONS, you choose your pline width for default and save your drawing as a template.
    Both of those variables can be set by using ACADDOC.LSP (Hit F1 and read about it) and input whatever you want when a new drawing is opened.
    For example:
    (setvar "mbuttonpan" 1)
    (setvar "plinewid" 25)
