• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    V
    Active Member
    mbuttonpan doesn't work!
    2705 Views, 9 Replies
    08-23-2010 12:02 PM
    When I type "mbuttonpan"  so I can depress my mouse roller ball to pan, it doesn't work.
    It worked on a different wireless mouse.
    The one I am currently using is a wireless Logitech EX100 mouse.
    V.
    Please use plain text.
    namssurt
    Re: mbuttonpan doesn't work!
    08-23-2010 12:22 PM in reply to: V
    set the middle button in setpoint to middle button.
    jg
    V
    Active Member
    08-23-2010 12:37 PM in reply to: namssurt
    jg,
    UMM... Where is the setpoint?
    V.
    V
    Active Member
    08-23-2010 12:52 PM in reply to: V
    Fixed it!
    Thanks!
    Active Member
    eelkovdm
    03-09-2011 02:11 AM in reply to: V
    I have a similar problem,
    I use a logitech G5 laser mouse, and have my scrolle wheel set to middle button in setpoint.
    mbutton pan variable is set to 1 and still I can't pan.
    it has worked on this computer but afther upgrading to AutoCAD Civil 3D 2011 is has stoped working.
    OS = Windows xp 64bit
    any other solutions to this problem out there?
    would be mutch appreciated
    *Pro
    M_Hensley
    03-09-2011 03:36 AM in reply to: eelkovdm
    To get my middle button to work properly with AutoCAD I had to go into control panel > mouse > wheel > exceptions and add AutoCAD as an exception.  (Not all mouse drivers have this ability.)
    Active Member
    eelkovdm
    03-09-2011 03:57 AM in reply to: M_Hensley
    I'm using setpoint and have added autocad as a "game" and then again set the scroll wheel as middle button.
    but no succes yet....arggggg
    New Member
    caspidopapidos
    03-09-2011 03:59 AM in reply to: V
    try setting a ne value, it must work interchage between <1> and <0> values
    Active Member
    04-11-2012 09:33 AM in reply to: caspidopapidos
    I have 2 different PC's with Logitech mice... One wireless, one corded. I have found that the Logitech SetPoint mouse software causes a major lag with the scroll wheel pan (with the scroll wheel set to Middle button instead of the default zoom). I have uninstalled the Logitech Setpoint software and the OS (Windows7 64 in my case) defaults the mouse to HID-compliant mouse. Pan and zoom on the scroll wheel work great in AutoCAD and the forward-back buttons still work in IE.
    Downside is that you will loose any additional button functionality on the mouse (Application switching, keystroke customization and other goodies)....  Not a problem for me.
    New Member
    02-09-2013 10:21 PM in reply to: namssurt
    This solution previously noted to set wheel as "middle button" in Setpoint worked for me.  It was somehow set as "Mouse:zoomset".  I set this under "Select Program - AutoCAD Application".  MBUTTONPAN set to "1".
