• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    ltscale will not update in xref
    2264 Views, 4 Replies
    06-02-2010 04:13 PM
    When i change the ltscale in the child drawing then go to the parent drawing, and reload the xref the ltscale does not update,
    I have to detatch the xref and then reattach the xref to get the ltscale to update.
    Is there a variable that controls this, very annoying
    Any help much appreciated
    thanks James
    Please use plain text.
    *A+P
    Re: ltscale will not update in xref
    06-02-2010 04:18 PM in reply to: jimsmart
    The LTSCALE setting only effects the drawing. It does nothing when the
    drawing is xrefed.
    Perhaps you're changing the Linetypes on Layers and because you have the
    parent dwg's VISRETAIN set to 1, that's why the Linetypes are not updating?
    What I typically do is rename the Layer anytime I change the Linetype or
    Color and etc on Layers so that the parent dwg will see the child dwg
    changes.
    Paul
    wrote in message news:6401732@discussion.autodesk.com...
    update.
    thanks James
    Member
    06-02-2010 06:29 PM in reply to: jimsmart
    Thanks Paul
    I am not sure what is going on, I am not changing any layers, just the ltscale
    Although when I originally attached the xref, my acad.lin file was different to the one i am using now, which may have something to do with it.
    James
    Active Contributor
    06-05-2010 03:08 AM in reply to: jimsmart
    thanks James
    In my drawing, when I detach and reattach the Xref to get the updated LTSCALE also not responding.
    Ram
    Ram.D
    *Pro
    06-07-2010 06:58 AM in reply to: jimsmart
    There are two potential problems:
    1.Most likely what is going on is that the linetypes that are needed for the xref were not loaded in the current drawing, and thus, they won't display properly.  In the current drawing, open the LAYER Manager and look at the linetypes of the xref layers.  If the format says "FILENAME|CENTER2" (where "filename" is the name of the attached xref), you simply have to change the linetype to "Center2".  You will most likely have to load the Linetypes first.
    2. Also, both the xref and current drawing may be using different LIN files (ie. the linetype definition files).  In other words, one drawing may be using the ACAD.lin file (ie. imperial) while the other drawing may be using the ACADISO.lin file (ie. metric).  To check which LIN file you drawings are using, enter the command MEASUREMENT in both drawings, and if one drawing is set to 0 (imperial) and the other drawing is set to 1 (metric) then set them accordingly, and then simply reload the linetypes using the LINETYPE command,
