AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
in school and need help figuring out something. ..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok i have been using autocad 2012 for some time now so i end up getting ahead of my teacher, well i created 2 drawings according to the book we are using, but he decided he wanted the drawings done in MM instead of Inchs, so i was wondering if there is a way to covert my drawing from inch to MM?
Re: in school and need help figuring out something. ..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the units drawn represent inches you can use the SCALE command and scale up all your objects by 25.4 to make them represent millimeters.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You could use the SCALE command to change the size of everything, but in the real world thats like hitting it with a sledgehammer. You will end up with odd-numbered sizes which is usually discouraged; most things need to be built and those in the field work faster with 1000mm instead of 1016mm. Certain manufactured objects are constructed and/or labelled differently in metric units than they are in imperial units so may not even be available in the that converted size.
Adopt. Adapt. Overcome. Or be overcome.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ty guys
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you to change the physical size or only the units of the dimensions? If you only need to convert the inch dimensions to equivalent size metric dimensions - that is pretty easy to do in the dimension styles.
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
...or you start a new drawing with a metric template, copy and paste the imperial one into the metric one, find a known metric dimension, then scale the whole thing by reference to the new dimension...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Perfect answer Bob!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-Q Boyce! ![]()
