• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    in school and need help figuring out something...
    335 Views, 7 Replies
    09-28-2012 10:59 AM
    Ok i have been using autocad 2012 for some time now so i end up getting ahead of my teacher, well i created 2 drawings according to the book we are using, but he decided he wanted the drawings done in MM instead of Inchs, so i was wondering if there is a way to covert my drawing from inch to MM?
    Please use plain text.
    *Pro
    M_Hensley
    Re: in school and need help figuring out something...
    09-28-2012 11:23 AM in reply to: dougy_8505
    If the units drawn represent inches you can use the SCALE command and scale up all your objects by 25.4 to make them represent millimeters.
    dgorsman
    09-28-2012 11:25 AM in reply to: dougy_8505
    You could use the SCALE command to change the size of everything, but in the real world thats like hitting it with a sledgehammer.  You will end up with odd-numbered sizes which is usually discouraged; most things need to be built and those in the field work faster with 1000mm instead of 1016mm.  Certain manufactured objects are constructed and/or labelled differently in metric units than they are in imperial units so may not even be available in the that converted size.
    Adopt. Adapt. Overcome. Or be overcome.
    Active Member
    09-28-2012 11:54 AM in reply to: dougy_8505
    ty guys
    09-29-2012 04:42 AM in reply to: dougy_8505
    Are you to change the physical size or only the units of the dimensions?  If you only need to convert the inch dimensions to equivalent size metric dimensions - that is pretty easy to do in the dimension styles.
    Bob_Zurunkle
    10-05-2012 09:12 AM in reply to: JDMather
    ...or you start a new drawing with a metric template, copy and paste the imperial one into the metric one, find a known metric dimension, then scale the whole thing by reference to the new dimension...
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    Distinguished Contributor
    Kazo
    10-10-2012 06:57 PM in reply to: Bob_Zurunkle
    Perfect answer Bob!
    Bob_Zurunkle
    10-11-2012 09:26 AM in reply to: Kazo
    10-Q Boyce! :smileyvery-happy:
