• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    i canot activate my licence,the activation window is stucked
    2319 Views, 6 Replies
    03-25-2011 06:38 AM
    thank the helpers.
    Please use plain text.
    Valued Contributor
    Re: i canot activate my licence,the activation window is stucked
    03-25-2011 06:42 AM in reply to: yaronw3
    the screen:
    Distinguished Contributor
    03-25-2011 07:10 AM in reply to: yaronw3
    Consider yourself Lucky!
    Autocad 2012 is a downgrade from 2011, big time!
    They don’t talk about it’s new features for a reason, and the reason is that THERE ARE NONE!
    They changed the UI once again to have a smaller workspace and be cluttered with 3D crap.
    What where they doing all year?
    Edited by
    Discussion_Admin
    *Expert Elite*
    Patchy
    03-25-2011 07:25 AM in reply to: donande
    Still can't draw double lines that can curve.
    Improvement, what a joke.
    03-25-2011 08:51 AM in reply to: yaronw3
    While you wait here for an answer to your question. I would recommend you also ask your question in the Installation & Licensing forum which can be found at the following link.
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    *Expert Elite*
    TravisNave
    03-25-2011 09:58 AM in reply to: yaronw3
    For more information on this known Autodesk Support Knowledge Base article, please follow this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Valued Contributor
    03-26-2011 02:26 AM in reply to: yaronw3
    Thank you ,i finnally succeeded with your autodesk help,i deleted the "broken zone" above "0-4 zones"'restarted my computer and all works .
    thank again.
    yaron
