• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    barry2104
    Accepted Solution
    how to delete a hole in my hatch
    1847 Views, 7 Replies
    01-16-2012 08:33 AM
    i opened up a drawing which had a hatch over an area, and after deleting some text from within the hatch extents, found that the hatch didn't ignore the text & put the hatch behind it, rather, it created an island around the text to avoid a hatch/text clash.
    I've removed a few pieces of such texts, and now have a bunch of rectangular holes in my hatch where the texts used to be.
    How can I remove these islands completely without having to rehatch the whole thing again?
    (I realise I could simply minimise the size of the island by picking the four corners/vertices of the hatch and bringing them closer together, but this is a messy solution)
    Thanks in advance
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: how to delete a hole in my hatch
    01-16-2012 08:40 AM in reply to: barry2104
    Try this, type in WIPEOUT,  F for frame, then ON
    If they show up, delete them or you can use QSELECT, and remove them in one swoop.
    Valued Contributor
    barry2104
    01-16-2012 08:52 AM in reply to: Patchy
    nope, nothing to do with wipeouts/Tframes.
    it's a simple hatch island, and can be created around text or other closed elements (e.g. a circle within a hatch boundary will also reveal such an island).
    all i want to do is delete the islands. I can remove one of the vertices of the rectangular islands, but the islands can't be reduced to less than 3 points using this method.
    *Expert Elite*
    Patchy
    01-16-2012 08:56 AM in reply to: barry2104
    Attach an example, let's see why
    Valued Contributor
    barry2104
    01-16-2012 09:00 AM in reply to: Patchy
    attached...
    *Expert Elite*
    Patchy
    01-16-2012 09:17 AM in reply to: barry2104
    Hatchedit, remove boundaries will work on the rectangles.
    The 3 circles are not boundaries, it's a continous line from the perimeter that is why you can't delete it.
    *Expert Elite*
    01-16-2012 05:45 PM in reply to: barry2104
    You could highlight the mid point grip of each arc, right click, and choose Convert To Line.  That will get rid of the circular holes.
    Valued Contributor
    barry2104
    01-16-2012 11:01 PM in reply to: Patchy
    to be clear for anyone looking for the process to resolve this problem without having to go through hatcheditor:
    1) select the hatch (you will see the "Hatch Editor toolbar come up at the top of your page)
    2) click on the Remove icon (LHS)
    3) click on a boundary of an island you want to delete & it will be removed instantly!
    thanks
    this would have been the slower solution going through hatcheditor COMMAND, fyi:
    HATCHEDIT
    > click "Remove boundaries" icon
    > select an edge of one/all of the islands you wish to delete (the entire hatch will look to be selected once you do this) then press enter/confirm
    > back in the Hatchedit window, you then need to click the "Display boundary objects" icon, which as far as i can tell, sort of regenerates the hatch. (if you simply click ok/close the hatchedit dialogue without clicking the "Display boundary objects" icon, then it won't work)
    > then you can click OK and you're good to go
