• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    how can I "fill" a hollow object that was created with the sweeping tool?
    604 Views, 6 Replies
    11-07-2012 10:55 AM
    I am trying to create a tube by sweeping a circle along a spline. I read many of the previous discussion threads on the topic but I still have some issues.
    I first created my spline and transformed it in a polyline (some people recommended to do it). Then I created the circle.  Finally I sweep the circle along the path.
    The issues are the following:
    1) when I look at the tube using the 2D wireframe mode, I can see that the primitives are not completely regular. In some points there are weird intersections and I don't know how I can fix them. Any hint?
    2) I hoped the tube was solid. However, when I exported (as .IGS) it and see in another program, I realized that it has only two circular caps at the extremities of the tube, but inside it is hollow.
    I tried to transform it in solid or mesh or whatever, but it always gives me an error, saying that the object cannot be converted.
    I think I am missing some fundamental step.
    I hope you can help me. Thank you in advance!
    Maria
    Please use plain text.
    Re: how can I "fill" a hollow object that was created with the sweepin
    11-07-2012 11:47 AM in reply to: maria.iacono
    Sweep along a spline would do just fine, no need to change to polyline.
    Test this drawing to see it still stay as a solid.
    Member
    11-07-2012 12:20 PM in reply to: Janet2009
    Hi Janet,
    thank you very much for your kind reply.
    I used your sample and it works exactly like mine.
    If I cut it tranversally in a random point along the tube, the section is a circumference, not a filled circle.
    Only the two extremities of the tube have filled circular sections.
    i hope you can help me.
    Thank you
    Maria
    11-07-2012 12:22 PM in reply to: maria.iacono
    Will the other program read .STL ?
    Member
    11-07-2012 12:42 PM in reply to: Janet2009
    It reads only ACIS (.sat, .sab), IGES, STEP Pro E, Inventor, CATIA, VDA, inventor, DXF.
    It is a program for biolectromagnetic simulations (XFDTD Remcom).
    11-07-2012 12:58 PM in reply to: maria.iacono
    Maybe use REGION command to turn the circle to region and then SWEEP.
    and you can also try ACISOUT command to get the .SAT file format.
    Member
    11-07-2012 01:38 PM in reply to: Janet2009
    Great!!!!! it works!!!
    Thank you very much! I really appreciate your help!
    Maria
