AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
exporting section-pe rimeter data-point s to text file
- Highlight
- Email to a Friend
Hi, I am completely new to the forum and to Autocad. I am using version 2011.
I am working with irregular solids and after I SECTION them, I would like to export to a text file the data points that make up the perimeter of the sections. I have tried googling for a way to do it but couldn't find any helpful information.
Could anyone give me a pointer in the right direction?
Ideally, I would like to do it from the command line, but that's a secondary goal, first of all I would like to know how to do it.
Thank you.
Pixe656
PD: I posted this same message in athoner forum and got no reply at all. Is what I am trying to do even possible?
Re: exporting section-pe rimeter data-point s to text file
- Highlight
- Email to a Friend
Possible, if we can see the parts.
Flatshot or use explode the 3d, run thru couple lisps and extract the points.
- Highlight
- Email to a Friend
Thank you for the information.
I tried Exploding the sections and "nothing" happened (I noticed no difference, I mean). Maybe I have to make a correction to my first post because I didn't mention the objects I am working with (the sections of an irregular solid) are "Region"s. Does that make any difference?
Using flatshot I got the perimeters, all piled on the same plane (OXY), and composed of "line"s. Then, using dataextraction I manaed to create a file with the XYZ coordinates. This is already good enough for me because I am not going to repeat this operation very often, but it's not exactly what I was looking for. Since the flatshot unites all the perimeters onto one plane, in order to have the information of each section independently, I have to flatshot them one by one, and then correct the Z value of each section (which faltshot makes equal to zero).
I am sure all that can be avoided using LISP but I have no experience at all with it, so...
Thank you again for your help.
Pixe
- Highlight
- Email to a Friend
Post your ? in the Lisp/Vlisp forum. You may find what you are looking for there.
- Highlight
- Email to a Friend
Thank you for your suggestion.
Just one comment: "Respect is EARNED, and NOT automatically given"
I disagree, one must be respectful to everyone. If you mean I can't just get everything I want from the members of the forum without making any effort, then sure, I agree. If you mean because I am new to the forum I deserve less respect than other members ...
Thank you again,
Julen
- Highlight
- Email to a Friend
That's his Signature, it doesn't mean he has anything against you personally.
Just ignore it.
- Highlight
- Email to a Friend
Respect is EARNED!!!!!!!!!! What you are talking about is common courtesy, treat others as you would like to be treated. You meet a guy on the streets, is he a child molester, criminal, politician or such?. You going to respect him. Not me. I will treat him with common courtesy as I would treat anyone else. I reserve my respect for veterans or soldiers who serve(d) to preserve my freedom and liberties.
This is a PHRASE and has no reference or intention to the people who post on these forums.
- Highlight
- Email to a Friend
My motherl language is not English and I had the feeling the word "respect" has the meaning you are giving it plus the one I am giving it. Also, I understood your signature as part of your post because I see no difference between the format of the main body and the signature, so I had no way to know it is your signature.
Anyway, thank you for your help and suggestions.
Pixe
