• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    ewolution
    error message when using "distance" command
    131 Views, 8 Replies
    10-29-2011 01:44 AM
    when I use the function "Distance" in AutoCad 2011, it  gives a fatal error...
    Please use plain text.
    *Expert Elite*
    Re: error message when using "distance" command
    10-29-2011 01:50 AM in reply to: ewolution
    you mean "fatal error" results in an AutoCAD crash?
    Have you tried it
    • with another drawing?
    • with another AutoCAD-profile?
    • as other user logged in to your Windows?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    ewolution
    10-29-2011 02:09 AM in reply to: ewolution
    yes i tried another files in my pc and autocad crash again...then i tried same file in another pc it is open...
    *Expert Elite*
    10-29-2011 02:12 AM in reply to: ewolution
    have you also tried with another AutoCAD-profile and with another Windows-account?
    Can you upload a screenshot of the window showing the errormessage?
    [EDIT] did you verify your installed servicepacks for AutoCAD? [/EDIT]
    - alfred -
    Alfred NESWADBA
    Member
    ewolution
    10-29-2011 02:19 AM in reply to: ewolution
    hi,
    i send u a screenshot...thanks..
    Evrim
    *Expert Elite*
    10-29-2011 02:26 AM in reply to: ewolution
    thx for the screenshot, my hope to get some info that could help you did not succeed.
    So now: AutoCAD-profile / Windows-account / AutoCAD-servicepack
    - alfred -
    Alfred NESWADBA
    Member
    ewolution
    10-29-2011 02:45 AM in reply to: ewolution
    hi,
    thx for your interest...i hope i find solution...or i will reinstall!!!
    Evrim
    *Expert Elite*
    10-29-2011 02:50 AM in reply to: ewolution
    Hi Evrim
    Why don't you look to the other three points I mentioned? IMHO this would be the best way to come closer to source of problem.
    - alfred -
    Alfred NESWADBA
    Member
    ewolution
    10-29-2011 02:58 AM in reply to: ewolution
    hi,
    ok sorry i will try this and if it is not work i will look another solution...
    thanks...
    Evrim
