• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Member
    error in drafting
    134 Views, 3 Replies
    12-29-2012 03:40 AM
    although my osnap - magnet setting is on, while starting a new line from end point / intersection point error is happening. this is leading to hatch boundry & champher command issues? Can someone help?
    a drg is attached
    Please use plain text.
    *Expert Elite*
    Re: error in drafting
    12-29-2012 04:16 AM in reply to: anatho
    Where do you try to start the line in your drawing ... and what error is happening?
    I tried some lines to start with active object-snap (end and int activated) and for me it looks like it's working as designed.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    12-30-2012 06:16 AM in reply to: alfred.neswadba
    Your drawing has a lot of geometry.
    Can you delete all the extraneous stuff that doesn't reflect the problem you are experiencing and re-attach the file?
    Can you reproduce the same behavior with a simple rectangle (or even a triangle)?
    Member
    01-15-2013 06:07 PM in reply to: alfred.neswadba
    i thought so too. when i put window on a wall n try to trim wall lines it does not happen. so i checked the dims with 0000 precision. thats when it started showing nano size errors. also it bugs a lot when hatch boundries do not get selected. this never happened in earlier versions cant see why its happening now?
