• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    draw arc tangent to a circle and a point
    605 Views, 3 Replies
    10-24-2012 12:31 PM
    Hello House,
    I am new here but I need help on how to draw an arc tangent to a circle and a point.
    The attachement here is a detail of the problem I'm having. No 9
    Please profer solution.
    Thank you
    Please use plain text.
    Valued Mentor
    Re: draw arc tangent to a circle and a point
    10-24-2012 01:24 PM in reply to: waridel
    Draw offsets from your items, draw a circle the same radius as your offset distance at the point where line cross, and then trim where you need too.
    Regards Steven Gray
    Setting Out (Joinery Manufacturing)
    Autocad 2013LT
    Windows 7 professional
    Member
    10-24-2012 10:29 PM in reply to: steven-g
    please attemt the head of the spanner not the handle
    Thanks alot
    Valued Mentor
    10-25-2012 11:53 AM in reply to: waridel
    You can draw the circle with a radius of 53 and the two lines that form the mouth of the spanner, all that information is given on the sketch. The curve you want I think is 30 but it is difficult to make out on the image, but using 30 all you need do is offset from the head of the spanner by 30, your new curve centre has to be somewhere on that offset  line. You cant offset from a point but you can draw a circle of 30 centred on that point, where these two lines cross is the centre you want.
    Regards Steven Gray
    Autocad 2013LT
