• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    CélineCELARD2251
    double click personnalisation
    282 Views, 5 Replies
    07-11-2011 05:56 AM
    How do I change the command used when I double-click and there is more than 1 selected object?
    I prefer to run the full properties palette  rather than qucik properties
    regards
    Luc
    Please use plain text.
    *Expert Elite*
    pendean
    Re: double click personnalisation
    07-11-2011 06:18 AM in reply to: CélineCELARD2251
    CUI command's DOUBLE CLICK ACTIONS section does that.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    CélineCELARD2251
    07-11-2011 06:48 AM in reply to: pendean
    Hi Dean,
    I think , you do not understand my problem
    in the Cui interface , I change the double clic action for the LINE object, using the property command
    open a new drawing, inserting 2 lines
    double click on 1 the the lines , the full properties palette appair
    selecting the 2 lines
    double click on 1 of the 2 lines , the quickproperties palette appair in place of the needed full palette
    and I have the same question if objects of differents types are selected
    regards
    Luc
    *Expert Elite*
    Patchy
    07-11-2011 07:04 AM in reply to: CélineCELARD2251
    Hightlight both, CTRL+1 or move the mouse over to the Properties Pallet , it will get the job done, it was made for that.
    Member
    CélineCELARD2251
    07-11-2011 07:24 AM in reply to: Patchy
    many times , the properties palette is closed , so I can't rollover it
    I know I'm a troublemaker , but I prefer the mouse to the keyboard , and this is a bad change comparing to the 2011 version
    *Expert Elite*
    pendean
    07-11-2011 11:26 AM in reply to: CélineCELARD2251
    To have a problem solved, you must explain it in detail first: try not to forget it next time :smileyhappy:
    while you wait... Consider adding what specific items you want to QP for each and all entities: for example you don't always need all 21 entries for a LINE all the time like in PROPERTIES, and QP can be placed in one spot instead of floating. CUI command to customize QP, real easy to do and takes less time that you've spent so far here.
