• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    deactivating ACAD 2010
    303 Views, 9 Replies
    02-23-2010 07:00 AM
    My company is not very large and we upgraded to 2010 almost 6 months ago.
    Our Licenses are for a certain number of copies. Last month we got the ok for some long over due workstation upgrades.
    The new machines are replacing the old ones, I am now running low on licences. Is there a way to deactivate the 2010 on their old
    machines to open the licence for the new one?
    Thank you for any help
    ~Ben
    Please use plain text.
    *Lance W.
    Re: deactivating ACAD 2010
    02-23-2010 07:11 AM in reply to: benperry
    What do you mean "running low" are these stand alone licenses? If they are
    you aren't running low you get more than oine install per seat for just this
    reason. I would make sure to wipe the install off the old machines though.
    Lance W.
    ______________________________
    my advice is congruent and factual..
    "benperry" wrote in message news:6342283@discussion.autodesk.com...
    > ~Ben
    Active Member
    02-23-2010 07:25 AM in reply to: benperry
    First off thank you for such a quick responce.
    By "running low" i mean we have one key and i was activating them and our distributer called and said we were
    coming close to our limit of activations.
    *Joel
    02-23-2010 07:59 AM in reply to: benperry
    Look into the Portable License Utility. That will transfer standalone
    licenses from one machine to another.
    Acad's "Help" will explain the step-by-step process, but basically, you load
    up Acad on the new machine, but don't authorize it yet - you have 30 days.
    Then there's some back and forth between the two getting machine
    names/numbers and such. But in the end, a license file is transferred from
    the old machine (which un-activates it) to the new machine which is then
    newly activated - and you maintain that one license in the process.
    *Nathan
    02-23-2010 08:24 AM in reply to: benperry
    I don't think these are standalone and if they are, Lance W.'s advice is
    wrong (no offence). The correct procedure for SA is to migrate your licence
    to the new machine not leave it behind or destroy it.
    You get one install, a 2nd if you are on Sub. Yes Adesk has grace - they
    know machines crash but it would be wiser not to test that grace.
    But the OP mentions 'limit of activations' so it's a multi user license of
    which I know little. He needs to release the licenses back to the
    "something??"
    "Joel" wrote in message
    news:6342336@discussion.autodesk.com...
    *Matt Kolberg
    02-23-2010 08:57 AM in reply to: benperry
    Given others' responses, your type of license is in question. This should
    easily be answered by your reseller.
    Matt Kolberg
    Global CADD Systems - A division of Cansel
    > ~Ben
    Active Member
    02-23-2010 09:00 AM in reply to: benperry
    "multi user license"
    Yes i have one code for about 10 users and i beleive our code has a 15 person limit wich unknowingly i came close to hitting.
    *Matt Kolberg
    02-23-2010 09:14 AM in reply to: benperry
    This is the best thing to do, though it's called the License Transfer
    Utility. Every time you need to move a license to another computer this
    utility should be used.
    Matt Kolberg
    > load up Acad on the new machine, but don't authorize it yet - you have 30
    > days. Then there's some back and forth between the two getting machine
    > from the old machine (which un-activates it) to the new machine which is
    > then newly activated - and you maintain that one license in the process.
    Active Contributor
    02-23-2010 09:59 AM in reply to: benperry
    Just went through this for 30+ computers were deployed as Win7. We just went ahead and activated.
    If it said the activation didn't go through, just go ahead and send the customer service request in. You'll get an email back asking why you should get more activations. Just tell them the computer was formatted and they'll give you a key.
    Active Member
    02-23-2010 12:43 PM in reply to: benperry
    Thank you everyone for all of your help
    We have a standalone license with 15 seats
    They reseller said exactly what Mike said to activate it and if we run into an issue to let them know and they will take care of it.
    Thnak you All
