• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    creating a place to insert blocks
    190 Views, 5 Replies
    01-15-2013 04:21 PM
    I worked with about 70 blocks that I routinely insert in drawings, at present I have an area where I keep all them in every drawing.  I would like to have a bar that will contain the blocks where I can drag and drop them into place.
    Thank you for any assistance
    Please use plain text.
    Valued Mentor
    Re: creating a place to insert blocks
    01-15-2013 04:47 PM in reply to: tbecker1
    You can do this with Design Center:
    Type ADCENTER at the command line, or Ctrl+2.
    Navigate to your drawing, on "Blocks" right click and select "Create tool palette".
    Member
    01-15-2013 08:09 PM in reply to: tschau3
    thank you very much, I'll let you know how it comes out.
    *Pro
    01-16-2013 04:31 AM in reply to: tbecker1
    You may also want to look into using Tool Palettes because you be able to create separate tabs for individual topics, like, a tab for Title-sheets, a tab for Annotation symbols, a tab for each discipline-specific symbology
    Member
    01-16-2013 05:56 AM in reply to: murray-clack
    Can you assist, or point me in the right direction. Thank you Thomas
    *Pro
    01-16-2013 05:58 AM in reply to: tbecker1
    Attached is a tutorial I created for my company on how to create Tool Palettes.  Let me know if it was helpful/useful.
