• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    stevo_08
    cannot draw vertical lines or rectangles in front, back and sides view
    689 Views, 4 Replies
    10-25-2011 04:02 AM
    On previous versions of autocad I used all views to draw lines and rectangles to produce 3d models, but now when i try it they only come up as horizontal lines.
    Please use plain text.
    Patchy
    Re: cannot draw vertical lines or rectangles in front, back and sides view
    10-25-2011 04:31 AM in reply to: stevo_08
    Which previous versions can do that?
    set it to e.g. SE view, you can,  but not front view.
    New Member
    stevo_08
    10-25-2011 04:50 AM in reply to: stevo_08
    2004 could do it. I was able to draw in all views, extrude the parts (walls, windows etc.), then join them together using an angled view
    Patchy
    10-25-2011 06:18 AM in reply to: stevo_08
    But if you look at front , back.... whatever view UCS icon, it only gives you x and y but no Z
    GrantsPirate
    10-25-2011 07:19 AM in reply to: stevo_08
    In your example look at the UCS, the X and Z are showing, change to an iso view or change the UCS so the X and Y show.
    When drawing 3D in AutoCAD it is best to have at least three viewports showing, with one of them in an iso view and the others in a front and right view, or top, etc. so you know for sure where you are drawing in space.
