• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    can't plot dwg to pfc. not showing in the preview
    185 Views, 1 Replies
    07-28-2012 12:45 PM
    i made a pipe plan. i create 6 layers of the plans. i made a border so that i can plot it perfectly with the others. after that i plot save it to pdf, at first there was no problem unti i started modifing the plans then at some point i cant save some of the plans to pdf. i don't know what happen. there is no error showing and i tried to see the process log and it shows that the process has been done, but there is nothing showing in preview. even if i save it the outcome became blank.
    in the plan i can't save the main, subdivision and hh plan. but i can save the line, discharge and dimension plan. they have the same property and size of border.
    Please use plain text.
    pendean
    Re: can't plot dwg to pfc. not showing in the preview
    07-30-2012 04:35 AM in reply to: khenchan
    Your main, subdivision and hh Layers are set to NOPLOT in LAYER command: that means they don't plot. Change the setting.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
