• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Accepted Solution
    bug in polygonal viewport
    1720 Views, 7 Replies
    06-15-2010 02:55 AM
    If you make a polygonal viewport on the "right" layer e.g. a layer that is set not to plot everything is fine - it does not plot.
    If you by accident make the polygonal viewport on the wrong layer e.g. a layer that is set to plot - and later move it to the correct layer - it will still plot. You have to delete the viewport and make a new one on the correct layer. I noticed this bug in 2010 and it is still with us.
    AutoCAD 2011 (Mechanical run in vanilla mode as part of AIP 2011)
    Windows 7 - 64 bit
    HP Z800 dual Xeon with 12 Gb
    Finnur
    Finnur P.
    AutoCAD Mechanical 2013 (run as vanilla ACAD)
    Product Design Suite Ultimate 2013
    HP Z800, Dual Xeon W5580, 12 Gb Ram, Windows 7 x64
    Nvidia Quadro Fx 4800
    Dell M6600 core i7, 16 Gb Ram, Windows 7 x64
    Nvidia Quadro M4000
    Please use plain text.
    Valued Contributor
    Re: bug in polygonal viewport
    06-16-2010 11:27 AM in reply to: finnurp
    I cannot duplicate this glitch, either by creating a polygon then using the select option in MVIEW or by creating a polygon within MVIEW. I created both on a plottable layer then moved both to a non plottable layer. I plotted the drawing out and no border was plotted around the viewport. Did you check to see if a polyline is sharing the same border as the viewport and is still on a plottable layer?
    06-16-2010 11:33 AM in reply to: finnurp
    After clipping the viewport there are two objects, one is the
    viewport and the other is the polyline.  Pick the object(s) then
    via the properties palette change the selection at the top to
    each item.  You can change the layer at that time.
    *Expert Elite*
    rkmcswain
    06-16-2010 12:17 PM in reply to: Jason.Piercey
    Well, I wanted to mark this as the "solution", but I suppose only the OP can do that?
    06-16-2010 01:11 PM in reply to: rkmcswain
    Evidently so.
    Member
    10-29-2010 12:03 PM in reply to: Dave_S
    I have experienced this bug before. He is right, I created a new polygonal viewport with the desired layer (Vport with plot turned off). The easiest way is to trace the outline of the bad viewport as a polyline, move it off the bad viewport, then do the view>viewports>object command. Since it is a new viewport, all the layers show up; I went into the bad viewport, saved the layer state, then went into the new one and restored the layer state I had just saved. Voila, a polygonal viewport that doesn't plot its borders. AutoDesk developers, please fix this, I've run into this situation a few times...Thanks
    dpb
    New Member
    dpb
    06-08-2011 05:58 PM in reply to: finnurp
    Yeah i've definately had this bug a few times. I wasn't aware that it could be fixed by first creating the vp on the non-plottable layer. I have found another soloution. I used matchproperties from a polyline on the non-plotable layer to the disfunctional vp and that worked.
    03-27-2013 01:16 PM in reply to: finnurp
    Drove me crazy for the last hour!  Ugh!  Thanks for posting the solution.  I was ready to head butt my monitor! lol
